Same Devices in 2 Repository possible ?
Devolutions Server 5.0.2.0
RDM 13.5.8.0 64-Bit
We have 2 Repository.
On named Online and one named offline .
In Online Repository:
I have some folders and devices inserted under a customer.
I export this Folder Tree to xml.
In Offline Repository:
Im Import this Tree.
When all entries was imported in Offline, the destroy me the same devices in online.
Sometimes only a few entries are imported. Then only this devices was killed in online.
What the hell is this ?
Andreas
Senior Network Consultant
Ostertag DeTeWe GmbH
All Comments (2)
Because the GUID of the entries are still the same, it moves the entry from your Online repository to the Offline repository.
I would recommend you to instead use the Copy-Paste operation and change the GUID so you will duplicate your entries in the Offline repository.
Please select all entries you want to copy and go in Home - Copy. Then, tick the Change ID option box and click on OK. Switch to the other repository and go in Home - Paste. This should do the trick.
Érica Poirier
Thanks,
this works fine :)
Andreas
Ends in 4 days
