Problem with renaming Connections
I'm working with RDM 13.5.9.0 64bit.
See the attached gif:
Thank you
Best Regards
Jonas
All Comments (5)
I have been able to reproduce your issue. A ticket has been opened to our engineering department.
As of now, the workaround would be to do a right-click on the session and select Properties and do the changes directly in the session.
:iagree:
Best Regards
Jonas
This is now fixed internally.
I checked the actual beta from today.
The "issue" is fixed, but you can't edit other fields except the name.
So I wouldn't miss this feature, can you please implement that?
Best Regards
Jonas
For now, it's by design. I will add a feature request for that but this is not simple.
