Prompt for comment on open
nalayon
Disabled
Hello Devolutions,
I need to change the configuration on several entries that I have already configured in RDM, what I need to change is the "Prompt for comment on open" option right now this option is disabled I need to enable it o all of our RDP sessions
Is there a way to do this without having to go one by one on each entry?, we are now using version 13.5.6.0
Can we change this configuration in batch?
Thanks in advance.
All Comments (8)
Sure you can enable the "Prompt for comment on open" option with the Batch edit feature.
In the Batch edit menu, choose Edit Settings (General Settings)...
And then enable the option in the Logs tab.
Érica Poirier
nalayon
Disabled
Great!
Thank you very much!
nalayon
Disabled
Now, one thing that I notice is that the log reports, are not as complete as in the previous versions.
I need to generate a report including the comments since I will configure that in all of the entries, is there a way to include more info in the activity log report?
thanks in advance
Which data source are you using?
Could you please give us more information about the missing information you want to have in the Activity Log report?
Érica Poirier
nalayon
Disabled
Hi Erica,
Im not really sure what is the type of data source we are using here.
Would you let me know how to get that information for you ?
thanks
Could you please go in File - My Data Source Information and send us the report by clicking on the small envelop on the top left corner?
Érica Poirier
nalayon
Disabled
Hi Erica,
I was able to resolve this.
Thank you for your help!
Best regards.
Thank you for your feedback. Glad that you have solved it.
Érica Poirier
