Session Check-Out without Comment
Hey there,
is it possible to disable the Comment-Box on Check-out of a session? We would like to keep the checkout-mode aktive to inform other users that a session is already in use but want to get rid of the Comment-Box.
I didn' t find anything in the manual.
All Comments (5)
I'm not sure to understand. You can leave the checkout comment empty. Do you want to just hide the prompt checkout dialog?
Yes - that is exactly what I want: Hide the checkout dialog prompt and start the session immediately (if it is not already checked out).
There is no option for that. That's something we could do. Do you want it per session or a global setting would be good?
Global has a higher priority for us. Per session with the possibility of inheritage would also be nice. I am thinking of scenarios where a customer insists of a report of all accessed sessions while other customers don' t.
Thx for the reply. For the moment we will have to get along with the 'unuseful' extra-click :)
Thank you. For now you can also press Enter to close the dialog.
