I have imported a large number RPD sessions. All of them have Clipboard sharing not enabled. I can turn this on for indivual sessions but I can't find a "global" setting to enable this on for all RDP sessions. Is this passible?
I'm running RDM 5.3 on a Mac 10.13.4.
Hi Michael,
You can select all your entries and execute a Custom AppleScript batch action. To do so first select the Custom AppleScript batch action:
Then, copy the following script in the Script field and press OK:
set value of _connection of property "UsesClipboard" to TRUE
save _connection
This should enable Clipboard sharing for all selected sessions.
Xavier Fortin
It would be possible to change this behavior to all your existing RDP sessions with the help of our Batch Edit feature
https://helpmac.remotedesktopmanager.com/actions_batch_edit.htm
