Citrix Netscaler add-on : no auto submit in 32 bit RDM client
I have found a minor bug, where the auto submit doesn't work in the Citrix Netscaler add-on with the 32 bit RDM client.
On the 64 bit RDM client is does work.
Auto fill is working, it just won't submit the credentials.
I have tested it with multiple versions (as of version 13.0.6) up till version 13.5.6 (latest).
All Comments (1)
Thank you for reporting this, we'll take a look at the issue.
