Problem with filter ctrl+f when having a tab that is a web page
Hi there,
I always use ctrl+f to find connections on RDM, I've upgraded to from v12 to v13 today and noticed if I have a website open on RDM, the ctrl+f shotcut will only bring find "find what" even on other tabs that are RDP for example. Even if I click and focus on navigation panel, I still keep getting find what instead of bringing up the filter.
I checked the options on the application to see if there is another way to configure this "find what" dialog but I can't find it. How can I make it behave as it should, just bringing this when focused on the website and not across my whole bunch of open connections?
Thanks!
I will have a look with our team about this.
Marc Beauséjour
I updated another one of my machines here to test and I've got the same behaviour. As soon you have a web page open in RDM it keeps stealing thefocus when you press ctrl+f to each in that page, even when another tab for a RDP session is open
Any luck with that?
I've got a few of my engineers complaining about the same problem since we updated from v12 to 13. Should I open a ticket?
Our engineers are continuing to investigate this issue.
Unfortunately, I cannot give you a date for an update.
Marc Beauséjour
We tried to fix this issue but we are not able to trap the shortcut before the third party component (web page). For now you could try to change the shortcut as a workaround.
Sorry about that.
Hi David,
Thanks for looking into this. Just bear in mind this used to work fine on v12.
still happening on latest update released today I believe?
