FEATURE REQUEST - Synchronizer for SCVMM (System Center- Virtual Machine Manager)
1 vote
I would like to have a Synchronizer for SCVMM.
SCVMM is the server that manages HyperV hosts same as vCenter for VMware.
This would be really helpful for me since we have over 30 HyperV hosts.
Thank you!
Do you know if you have a powershell script or a way to get the session list from SCVMM?
Yes you can.
The following command will get you the list of all virtual machines.
Import-Module VirtualMachineManager
Get-SCVirtualMachine
Thank you
Bonjour
Un petit UP pour cette fonctionnalité pour SCVMM et Console FailOver afin de gérer au mieux les CLUSTERS avec bascule automatique
Thank you
Wanted to follow up on this and see if you guys made any progress with the VMM synchronize?
Would also be interrested in a SCVMM Synchronizer, as we currently have one for each hyper-v host, which is not optimal
Would be great if the Synchronizer could have an option to select all cluster/hosts/vms or just specific ones.
