1. chrome extension slows down chrome dramatically. this happens on multiple computers with multiple os's on different environments
2. chrome ext keeps looping (circle is spinning) and not finding and as a result, not autofilling the forms (office 365 for example)
About the Chrome Extension slowing down chrome dramatically. Does it happen to all the data source you are connecting to? Does your data source have a lot of entries in it? Does it also happen when you connected to a data source with not a lot of entries?
About the filling of Office 365, a fix will be available in the next extension version.
Olivier Désalliers
problem not yet resolved
since 13.0.6.0, the autologin to 365 stopped working
even with the latest chrome, latest extension, and latest rdm
what to do?
Does Devolutions Web Login still keeps looping?
Olivier Désalliers
1. i've tested on 2 data sources
2. one of them around 2k entries and one about 3k entries, but it started on both of them after the update
3. didn't try with a small amount of entries, but it doesn't matter. it should work (and it had worked) regardless of the amount of entries
We will try to reproduce your issue. To be sure to have the same environment what is your data source type?
Olivier Désalliers
sql server
i have in 2 different sites, same problem
