SSH problem with Cisco SSH-1.99-Cisco-1.25
badarighe
Disabled
I'm trying Remote Desktop Manager for Mac OS. The configured SSH Shell connection don't work. I've found a trick to make it work.... Edit Entry>SSH Shell>Advanced and select Verbose, set to 2 and select Enable logging. This is the only the way to work.
All Comments (10)
I'm moving your post to the Mac thread since you're using RDM Mac.
What version of RDM are you using?
Marc Beauséjour
badarighe
Disabled
I'm using 5.2.0.0
Only with level 2? Can you get us the log file generated? You can send it to me via email: xfortin@devolutions.net
Xavier Fortin
badarighe
Disabled
yes, only level 2
And how about the log generated through the "Enable logging" option? Can you send it to me?
Xavier Fortin
Hi again,
Just to make sure.
If you disable Verbose and Enable logging, your connection fails to open successfully?
If you set the Verbose mode to anything else than 2 (1, 3 and 4), it still fails?
The log you've sent me, for which scenario was it?
Could you send me the log with those configurations:
Verbose: enabled
Enable logging: true
Verbose level: 4
I'd like to inspect the log of a failing session.
Xavier Fortin
I have reproduced this exact scenario. The session works from Windows RDM, but not Mac. It opens to a black screen and never connects. If you enable verbose 2, It hangs at 'ssh_analyze_banner: SSH-2.0-Cisco-1.25'. If you enable logging with verbose 2, it connects normally.
Attached are verbose 1-4 logs as requested above.
Hi Brad,
Thanks for the log. We look into them and see what we can find.
Xavier Fortin
Just tried 5.3.0, and unfortunately this issue still exists.
Hi Brad,
We still haven't figured out this specific issue. We're working on a new engine for our SSH Shell session that might solve this issue or, at the very least, make it a lot easier to troubleshoot. That being said we still have an engineer looking into this.
Xavier Fortin
