Problem creating folder in 13.5.0.0
Upgraded DVLS and RDM today to 5.0.0.0 and 13.5.0.0
After this I have noticed that I get problems when trying to create a new Folder "Add - New Folder"
When doing this in 13.5.0.0 i get "You don´t have the permission to add an entry in the root folder"
It does not matter how deep in the folder structure I try to create the new folder, get the same error everywhere
In "Administration - Root Setting" I have permissions set to "Custom" and only allowing Admin and members of a Administrators group to "Add in root"
Root
Folder Level 1.0
Folder Level 1.1
Folder Level 1.1.1
Folder Level 2.0
Doing the same now but with older 13.0.6.0 workes fine
All Comments (28)
Does the Windows Authentication option is enable in your DVLS data source configuration (File - Data Sources)?
Érica Poirier
Hello
No , that one is not checked.
Also I can add that it workes fine to add sessions at the same place that i can´t add a new folder.
I am unable to reproduce your issue.
Do you have something relevant in the DVLS logs for this issue? If so, could you please send us the detailed error message?
https://helpserver.devolutions.net/configure_dvlslogs.htm
Érica Poirier
Hi
No, nothing is written there when I get the problem.
It´s very strange problem. I can create folders if i user Add - from template , but not if i choose "Add Folder".
I don´t now if this has something to do with it but when I add a new Role and under Permission there is no option for "Add in root" anymore as it is on the older Roles that we had before where Add in root is set to "Default"
I also can add that if i login as Admin i can create folders
We would need to check your permissions to see if everything is set properly.
Could you please go in Administration - Root (Settings) and post a print screen of the Permissions tab of the Root properties?
Érica Poirier
Attached my settings.
I have added my self "mf" , but as you can se in pic2 i still have a red X
But as i wrote , if i use an older RDM client (13.0.6.0) it workes fine to create the folder
Thank you for the screen shots.
Could you please also post a screen shot of the General tab of the user properties?
Érica Poirier
