Wayk Now Connection Using Session ID
Is there a way to connect to a Wayk Now remote session using the session id. I have tried and it will not connect. I did see where you have mentioned adding PTR records to the DNS servers but was not sure that would help.
Thanks,
Lee
Hello Lee,
If you use the Wayk Now Session ID you should be able to connect to Wayk Now base on Wayk Now help topic : https://helpwayk.devolutions.net/gettingstarted.htm
But If you are trying to connect via RDM to the new Wayk Now 2.0 you need to use RDM 13.0.18 (Beta version) to connect with the Session ID.
David Grandolfo
I was trying to use the RDM WayK Now Remote Session in RDM to connect. Thanks, I will try and get my hands on the BETA if possible.
You are welcome, if you have any issue or questions please let us know.
David Grandolfo
