[return] doesn't work when Treeview is not docked
theovds
Disabled
Good morning!
I'm an enthusiastic user of Remote Desktop Manager. Its a great product and makes a lot of things far more easier!
I'm using RDM 13.0.18 (64bit) and found a bug. By default the Treeview is docked. I moved it to my other screen to have more space for my connections. When I use the filter to search for a connection, I'm unable to use [return] to open the connection. If I moved the Treeview back to RDM (docked) its working again.
Hopefully your able to reproduce this and create a bugfix.
Thank you!
All Comments (6)
Hello Theo,
If I understand correctly I'm not sure that we will be able to fix this. To avoid Enter shortcut conflict we check that the main form has the focus. Could you send me a print screen (in private if you want) with the setup you have?
This is now fixed internally.
theovds
Disabled
Thanks! I'm not able to test the latest beta (where the bug is fixed), because of the needed DB upgrade. I'll test it, when the new build is out of beta.
Thanks again for your work!
theovds
Disabled
I've installed the latest version (13.5), but its not working. What could be the problem?
Edit:
Lol, after a restart, its working as expected. I don't know why :)
Thanks for fixing this!
This is strange. Let me know if you can reproduce it again. Perhaps I missed an edge case.
theovds
Disabled
I can't reproduce it again. It's working on both x86 and x64.
Thanks!
