RDM 13.0.6.0 focus issue with searches
gabriel
Disabled
We are using RDM 13.0.6.0 and I have an issue with the Quick search bar at the bottom left.
In exemple the Navigation bar is opened and I use the quick search to filter the results (on the screen attached). In this case if I right clic on IXIONEXCH01 in the Navigation bar, I will get the options for IXIONEXCH02 because it's the server with the focus in the search Window (Properties will give me the properties of IXIONEXCH02 and delete will delete IXIONEXCH02).
It's a little bit confused when I would like to delete a server based on searches or copy a password. The server I right clic on in the navigation bar is not always the same as the one selected in the search Window.
Best regards
Gabriel Maret
All Comments (4)
Not sure to fully understand the issue.
Could you post a small video of the issue, so that we can try to reproduce it internally.
