Using integrated Dameware Connection with VNC does not connect due to password error
michael14
Disabled
Hi there,
since we updated to Dameware 12.5 from Dameware 9 our existing Dameware host entries configured with VNC Server do not connect. The error Message is:
"This VNC server requires VNC authentication. Please enter the VNC credentials in the Remote Connect dialog."
When entering the credentials in Dameware Remote Connect window it works fine.
Any help is greatly appreciated!
Michael
All Comments (9)
Hello Michael,
We'll take a look at this, thank you for letting us know.
We use command line parameters to send the Information in RDM.
Here's a list that we found for DameWare;
Could you please try through command line out of RDM to see if it works?
Also, are there any special characters in your password?
Marc Beauséjour
michael14
Disabled
Hi Support,
good suggestion, thank you!
It does work when i use this:
DWRCC.exe -c: -h: -m:t-13364.myskm01.myskm.net -vnc: -a:0 -p:mypassword
But it does not work when i use this RDPM configuration:
It doesn’t matter which Authentication mode is choosen. We do not have Special characters in our Passwords.
Michael
Hello Michael,
I think I know what's causing the issue. Does your Dameware entry link to a credential entry that has a username? I think since RDM finds a username in the credential entry, it automatically passes it in the command line. Could you confirm?
michael14
Disabled
Hello Hubert,
no, my credential entry only contains a password.
Michael
Hello Michael,
I attached to this post a small application that simply returns back the command line parameters you sent it. Could you rename the executable to "dwrcc.exe" (what RDM looks for) and change the path to point to it in File > Options > Path > Configure Installation Paths. It should give you what exactly RDM is passing in parameters when you try to open your dameware entry.
michael14
Disabled
That's it, great tool :-)
This works:
DWRCC.exe -c: -h: -m:t-13667.mydomain.net -vnc: -p:mypwd
DWRCC.exe -vnc: -c: -h: -m:t-13667.mydomain.net -p:mypwd
DWRCC.exe -vnc: -p:mypwd -c: -h: -m:t-13667.mydomain.net
This does not work:
DWRCC.exe -c: -h: -m:t-13667.mydomain.net -p:mypwd -vnc:
DWRCC.exe -p:mypwd -vnc: -c: -h: -m:t-13667.mydomain.net
The output of your tool was:
-c:
-h:
-m:T-13667.gemeinschaftsklinikum.net
-p:pwadmin
-vnc:
So I think, in newer versions of Dameware the -vnc: parameter must be set before the -pwd: Parameter
Is there a way to change the order of parameters in RDPM?
regards
Michael
Good find, Michael :) We'll change the order and put "-vnc:" (and also "-r:", which is for RDP) as the first parameter. This will be available in the next build of RDM. If you could let us know if this works it would be appreciated.
michael14
Disabled
I checked the function in version 13.6.2 and it works fine now!
Thank you!
Michael
