Passing Entry Variables into Applications or Shell Scripts
jroashe
Disabled
In RDM, there are entry variables such as $INFORMATION_COMPANY$, $IP$, $USERNAME$, $PASSWORD$, etc.
I may have my username and password in a private vault, but I want to pass my $USERNAME$, $IP$, and possibly $PASSWORD$ into a powershell script.
When I launch a powershell entry from within RDM, I want access (in powerhsell) to the RDM entry variables $USERNAME$ and $IP$.
All Comments (5)
To use the RDM entry variables in a PowerShell script, you just have to use them directly in the script.
Here is a sample :
If you want to use the password variable in the script, you need to enable the Allow password in variable option in the Security tab of every entry you want to use your PowerShell script.
To configure all your entries to enable the Allow password in variable option, you can use the Batch Edit feature - https://help.remotedesktopmanager.com/edit_batch.htm
Érica Poirier
jroashe
Disabled
I tested this and was not able view the value of variable $HOST$ in the script.
Also, the second image that you have displayed regarding "Allow password in variable" is not an option with Macros/Scripts/Tools entries.
Could you please post a screen shot of the properties of the PowerShell entry you are using and also the content of your PowerShell script?
The Allow password in variable option is located in entries like RDP, SSH but not in the Macros/Scripts/Tools entries.
Érica Poirier
I have a similar issue with Custom fields
I have created a custom filed name ServerID and interested data into it.
I am unable to pass this data to a script in events.
I was able to use system variables.
I am using the latest version of RDM
Let me know if the answer I provided on the following helps.
https://forum.devolutions.net/topics/39349/using-events-before-start#175430
Érica Poirier
