We are using the Management Studio Add-On to connect directly to SQL databases.
Without jump (direct) it work fine (RDM 13.0.6.0 / Management studio 17.4), but with Jump the Management studio doesn't start on the Jump host. I connect on the jump host with local admin (last agent 1.3.0.0)
Is there anything I can try to make it working ?
Thanks in advance
Best regards
Gabriel Maret
Is SQL Management Studio add-on installed in the jump host as well as RDM?
Yes, I reinstalled the add-on on both the jump and the RDM servers.
Best regards
Is SQL Management Studio installed on the jump host?
Yes, The connection work fine without jump from the RDM server or the Jump server. The same Management Studio is installed on both of the servers.
Best regards
Thank you for all the information's.
Let us investigate this issue and get back to you.
As per the video in attachment, we have not been able to reproduce your issue.
Could you post a small video of your scenario and/or attach your 2 sessions (without the credentials) so that we can analyze them.
