Prompt for Entry
I'd like to know if RDM has the ability to partially configure a connection and have a prompt to enter the Host or IP for that connection. What I'm trying to do is create one entry to use for multiple sources. We use VNC in our environment and the only difference between hosts is the host name. So if I had a VNC entry that had a popup requesting the host name I could reduce my current workstation list from 400 entries down to just 1.
All Comments (2)
Could you try to create a template (or multiple templates) and use them with the Quick Connect feature.
These links should help;
https://help.remotedesktopmanager.com/file_templates.htm
https://help.remotedesktopmanager.com/view_quickconnect.htm
Not exactly what i was looking for but it will do just what i need. Thank you so much!
