Ping with sound (beep)
sophos2
Disabled
herewith I would like to make a request for the following feature:
The continuous ping is accompanied by a beep noise.
This feature will help in the following scenarios: If you have many windows and apps open, you can move the RDM to the background while rebooting VMs or physical hosts.
Have a look on bPing. (gizmoware(dot)net/bping/
it would also be great if you can reverse the decision when the beep will take place. either if the ping works or if systems are absent.
What do you think?
Best regards
Tom
All Comments (1)
Hello Tom,
I will add a feature request.
