Possibility to use credentials from private vault for session-tools
can you provide the possibility to use credentials from the private vault for session-tools like for the session itself?:
Kind regards,
Nico
This is possible using the User Specific Settings feature to override the Tools Credentials.
https://help.remotedesktopmanager.com/edit_userspecificsettings.htm
For test purposes, I have stored in the normal settings as well as in the user-specific settings a Tools password. Under "After Connect - Macro" I have deposited the variable "$TOOL_PASSWORD$". When I start the macro with "Execute Typing Macro" I get as output the password stored in the normal settings, not that from the user-specific settings. Do I have to use another variable to use the user specific password?
There's maybe a bug. We will try to reproduce and get back to you.
Could you please send us a print screen of your RDP entry General section and one of your Tools section. This will help us greatly in reproducing your issue
James Lafleur
Hi James,
yes of course:
Kind regards,
Nico
The issue has been submitted to our engineering team and we will notify you as soon as we get any update on your issue.
James Lafleur
