Network Scan Remote Sites not / partially working
jeroen01
Disabled
I'm currently testing the Trial version of Remote Desktop Manager and generating a complete overview of our Network Infrastructure. Using the Network Scan tool to import switches and routers has been working great however we have several sites over the world which don't have the fastest connection.
I noticed that the Network Scan is having problems with picking up everything on these sites. It feels as if the 'Ping before scan' discards the scanned IP address if it didn't reply within a really fast response.
Is there to increase the delay of the ping before the Network Scan starts with the next IP address in the scope? I'd preferably not disable the Ping before scan because scanning an entire /24 takes a lot of time then.
Please see the attached screenshot for what the Network Scan found and some ping results of devices in that subnet which should have been picked up.
I've been able to retrieve the information I need by installing the Trial Version on a local machine on the subnet I wanted to scan but installing the entire software for a simply network scan is quite a cumbersome task if it's needed on a lot of remote sites.
All Comments (6)
I will assign this to one of our dev to check if we have an option for that. I think it's hard coded.
