Open webpage external with IE / embedded with Chrome - issue when use DPI scaling
When I open IE externally on my 15" 4K monitor (scaling factor of 175%) there seem to be issue's with the scaling factor => see printsceen in attachment.
Note that the default is zoom is set to 100% and when I open IE normally this defaults to 175%.
When I open IE tabbed I haven't got this issue. Also chrome seems to be working fine.
FYI: I have the 'disable display scaling on high DPI settings' set unchecked.
All Comments (5)
Update: in Chrome the embedded - tabbed version is not working properly (see attachment)
What version of Windows 10 do you have? Could you please show us a screenshot of the winver.exe window?
Have you also tried the other solutions offered here?
https://help.remotedesktopmanager.com/troubleshooting_hdpiscalingissues.htm
Mark Beausejour
Do you use a standard scaling like 150% or 200%?
I am using 175% and 100% ...
still having this issue. Any update?
Note that I set 'Override high DPI scaling behavior" => System (Enhanced)
( https://forum.devolutions.net/messages.aspx?topicid=26129&Page=2 )
