Possibility to create a shortcut from a sub connection
would be nice if a shortcut can also created from a sub-connection - at the moment it is only possible for the parent entry.
Best Regards,
Min
All Comments (6)
Hello Min,
Unfortunately our sub connection architecture does not allow us to do that. It's saved in Parent connection.
Hi David,
That's a pity - but thanks for the information - then I will think about a workaround ;)
Best Regards,
Min
What was the scenario? Perhaps we can help.
Attached an example of a typical structure from our entries - the goal is to have a shortcut for the VMware Konsole below the Company level. For the VMware entries it can be a workaround to create a server group and configure independent entries - now the shortcut for the specified service can be configured.
But we have also RDP as main connection with subconnections, and to use here the folder workaround is a little bit awkward - specially if you want to use the inventory feature. Then you have mixed rdp entries and server groups on the same level - and this is what I would like to prevent.
Thank you!
Min
Company.rdm
Sorry for the delay. For now I have no idea on how we could resolve this. I will continue to think about it.
No problem, it is not such urgent ;)
All the best for the new year! :cheers:
Min
