SSH shell (rebex) sessions loose focus since 13.0
something has changed with 13.0. I waited until 13.0.5 but still the ssh sessions are losing focus when using key combos. I think they are mostly alt-.. or alt-shift comobos (like history: alt-**** H in midnight commander). you need to click into the session with the mouse to get the session accept keystrokes again.
All Comments (7)
Could you give me an example of key combos that you use? I would like to reproduced the issue internally.
If I understand correctly the steps to reproduced it are:
1. Start a SSH Shell (Rebex) session
2. Do the xxxx key combos
3. The focus is loose, we need to click back on the terminal to be able to type again.
David Grandolfo
it's definitely alt-enter and alt-shift-h
This issue should be fixed in version 13.0.7.0.
Is there an ETA? this gets quite annoying
@perler,
What version of RDM are you using?
Could you try RDM 13.0.8.0? You can download this version here
https://remotedesktopmanager.com/home/download#Beta
thanks, much better. do I get a notification when the final version is released?
Depending on your configuration in File -> Options -> General -> Application Start, you should be notify at startup on new update.
