Hello.
I use tabs for grouping several RDP sessions. Since RDM 13, the RDP window does not fit perfect when the tab opens the first time (see Screenshot). SmartReconnect does not work here, because the session opens before the tab appears.
Thank you for fixing that.
Could you post a print screen of the Display tab located in the properties of your RDP session please.
Hi Jeff
Of course:
Could you go in File -> Options -> Types -> RDP and set the RPD engine to RDP 8.1 please.
What version do you use? We did a fix for that in RDM 13.0.4
