WatchGuard SSL Addon Issue
I've updated the addon to the latest version which is 1.2.0.0.
However this has caused issues and the RDM entries won't open. The application is throwing an error in regards to the file path.
It is trying to find a file 'WGSSLVPN.EXE' however this doesn't exist. The correct file is actually 'wgsslvpnC.exe'
The addon, RDM and SSL VPN is all on the latest versions.
Any ideas?
All Comments (5)
Same problem here.
Is there a way to revert to the old version?
We just published a new version of the add-on (1.2.1.0) which supports "wgsslvpnc.exe". Could you install it and see if it works?
Working fine now. Thanks for that.
Does this new version add support for passwords? Or simply usernames.
Unfortunately we don't support automatically sending the password to the WatchGuard program. I'm not sure if it's possible to do since we don't have the program internally and it doesn't seem to be a documented feature.
The workaround is to use a macro to enter the password. Variables like $USERNAME$, $DOMAIN$ and $PASSWORD$ are able to be used in the macro if you use the credential repository.
