I'm using Firefox 56.0.2 (64-bit), which is the latest stable build as of this writing.
I have the addon Disconnect installed. It's a great addon and is a much better alternative to Ghostery (they sell your data/leak information, according to articles found online).
For some reason, I cannot make a forum post, or edit an existing one, if I have Disconnect installed. Even if I whitelist the forum in Disconnect, I still have the same issue. The only fix is for me to remove the addon from Firefox.
Now, it sounds like an issue with the addon, but I do not have this issue on other websites. Just wondering if you guys are able to replicate it on your end and is there perhaps something on the front-end that doesn't play well with Disconnect installed?
I'm always using the latest beta RDM x64 version.
Local data source.
Do you have a link for this add-on. I could ask our team to do a test with the add-on installed.
Here you go:
Local data source.
