Different connection options per hostname?
Hi.
I currently use the enterprise edition from both a work computer, a laptop and a home system. I have my RDP resolutions set down to 1024x768 so that the session fits on the laptop screen. I would very much like to be able to set the resolution higher while working on a larger monitor (home/work.) Does any functionality exist today that might help accomplish this? Maybe an "override template" that could be based on monitor resolution, monitor identifier string, hostname, dropdown in the client, etc..
thanks for your time. This tool makes my works so much easier to manage.
All Comments (6)
Have you tried the Edit (Local Machine Specific Settings) menu?
That seems to be the ticket.. thanks. Is there a way to apply that to all of my existing connections in bulk or through inheritances or do I have a lot of clicking to do?
I don't think it's possible to do that in batch :(
Actually you can, select all your RDP sessions, right-click -> Batch Edit -> Edit Sessions (Local Machine Specific Settings)
Stéfane Lavergne
Awesome, thanks. So many options available I just don't see them when I am looking for them.
Me too :)
Closed
