I very often get the message below, and have to retry 4-6 times. It only happens with RDP Engine V5, not V4.
Hi Jesper,
I think there might have been an issue with the attachments. Could you try posting the image back?
Xavier Fortin
Attached it as a JPG in the previous message.
Hi Jesper,
I think I might have come across a similar issue last week. I'm having trouble reliability reproducing it though. Does the issue always occurs on the same sessions? Is it always happening? Or can you sometime open said sessions without issue?
Could you try switching the Sandboxing? I'd like to find out if this has anything to do with the communication with the external process.
Xavier Fortin
I've been running without sandboxing all day, and not a peep, so you may be right...
I've logged the issue, but this one risk being quite tricky. For the moment, if you have no issue without the sandboxing, I'd suggest disabling it for all faulty sessions until we find a more suitable fix.
Xavier Fortin
