Hi, I use this string connect from putty, the gateway is record the SSH session and require LDAP authentication before the actual server authentication, I tried to add the <PSM IP> to SSH jump / gateway but no working, any idea?
<username>@<Server IP>@<PSM IP>
Using username "<username>@<Server IP>".
SSH server: Gateway authentication and authorization
Using keyboard-interactive authentication.
Please specify the requested information
Gateway username:
Gateway password:
<username>@<Server IP>@<PSM IP>'s password:
Since this is not a traditional gateway, I don't think the gateway section would work as it currently is. When you tried using the gateway by putting in <PSM IP> in the gateway host, did you also put <username>@<Server IP> in the "username" field? If not, could you try that?
To confirm with you, you enter the command "<username>@<Server IP>@<PSM IP>" in the remote command section of PuTTY, right? Then I think if the first option fails, entering that command in the "after login commands" section of the entry may work. Something like that but with your own values:
it's under SSH shell (Rebex), I don't have tab for "after login command" that is release under which version?
Hi Francis,
which version do you use?
The mentioned After Login Commands are in a SSH Shell Session available.
The SSH Shell (Rebex) Entries are depricated, I recommend to use the native SSH Shell Session type. This post explain the difference (in this case it was a putty session, but this applies also to Rebex Session types)
Best Regards,
Min
