I can't establish a connection to a Server using Network Level Authentication in embedded mode.
External mode works fine. The error message is:
"The remote computer requires Network Level Authetication, which your computer does not support".
I am running Windows XP SP3 with the necessary changes to the registry to allow Network Level Authetication.
I can use the regular Remote Desktop app. and it allow Network Level Authentication.
The remote desktop activeX control version is 6.0.6001.18926.
The Remote Desktop Manager version is 8.2.0.0
Thank you,
Richard
Have you enable the NLA on the RDP settings?
What version of RDM do you use?
Yes the NLA is selected.
Under the connections TAB the Active Network Level Authentication (SingleSignOn)
RDM is 8.2.0.0
Could you try to install this update? Perhaps you already have it installed
It worked....
Thanks very much for your prompt attention to this matter.
Richard
