i encountered that if the program you call through jumphost (vi-client, putty, etc.) is not configured on jumphost
the window for "Application Installation Path" opens and goes into background and
cannot be filled with required information.
Kind Regards
Markus
I will assign this.
Hello Markus,
I tested with PuTTY and I'm unable to reproduce the issue, the window is on top of RDM instead of under:
My workstation's RDM version is 12.6.8.0 and the jumphost's is 12.6.1.0.
Could you tell me the RDM version of both your workstation and the jumphost? I must be missing something if I'm not able to reproduce this issue.
Hi Hubert,
I'm sorry for my delayed reply.
I Updated to the last versions. My Jumphost was 12.5.12.
Since the update to 12.6.8 I didn't encounter the problem again.
Thanks for your help.
Kind Regards
Markus
