When connecting to ICA Connection Server, i recieve the below error:
NotImplementedException - Invalid parameter
at WFICALib.IICAClient.set_WorkDirectory(String pVal)
at AxWFICALib.AxICAClient.set_WorkDirectory(String value)
at Devolutions.RemoteDesktopManager.Frames.Embedded.FreEmbeddedCitrix.Setup(Connection connection, OpenConnectionMode openConnectionMode)
at Devolutions.RemoteDesktopManager.Managers.EmbeddedViewManager.OpenEmbedded(FreEmbeddedView frame, Connection connection, Boolean isConnected, Boolean showFooter, OpenConnectionMode openConnectionMode, Image image)
at Devolutions.RemoteDesktopManager.Managers.EmbeddedViewManager.Open(Connection connection, FreEmbeddedView frame, Boolean isConnected, OpenConnectionMode openConnectionMode, Boolean undocked, Image image)
at Devolutions.RemoteDesktopManager.Business.Connectors.EmbeddedConnector.Connect(Connection connection, OpenConnectionMode openConnectionMode)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.OpenConnection(Connection connection, OpenConnectionMode openConnectionMode)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.OpenConnections(Connection[] connectionList, OpenConnectionMode openConnectionMode)
at Devolutions.RemoteDesktopManager.Managers.ActionManager.DoOpenConnection(Connection[] currentConnections, OpenConnectionMode openConnectionMode, IConnectionSource source)
at Devolutions.RemoteDesktopManager.Managers.ActionManager.OpenConnections(OpenConnectionMode openConnectionMode, IConnectionSource source)
at Devolutions.RemoteDesktopManager.Managers.SessionMenuManager.MnuOpenConnection_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
below is my configuration:
Embedded Mode
`-Custom Configuration
`-Computer: server.citrix.com
`-Port: 8443
`-Username: User
`-Password: Userpassword
`-Domain: Domain
`-Programs
`-Program: "Server Desktop"
when adding the Program i recieve the error.
without the program however i do not achieve a connection and it times out.
can you please help?
This component (Citrix ICA/HDX) does not support Citrix web url. However you can create Citrix (web) session type and try it.
Hi David,
could you please provide a sample configuration?
Sorry for the delay. What do you mean by sample configuration? Do you have an url to access your server?
