RDP connection templates - setting a non-default port number
Currently the software will allow you to change the default port in the template, but the setting does not apply when new objects are created with the template.
Have you changed the default port in File -> Templates -> Default Settings -> Session -> Microsoft RDP?
Apologies for the late response. I just encountered the issue again this morning.
RDM Enterprise Edition v12.6.8.0
We are creating sessions using synchronizers, I have created a shared template with the updated port information. The synchronizer is configured to use this template.
What type of synchronizer are you using? The Active Directory Synchronizer?
Yes sir that is correct. I have attached relevant screenshots.
Jeremy
We have been able to reproduce your issue and a ticket has been submitted to our engineering department.
We will investigate.
Thank you so much for reporting this!
Marc Beauséjour
Thanks!
We've made a fix internally, it should be available in the next RDM beta.
