Entry-Type Software/Serials Problem
we have some entries by type Software/Serials where I added Links to Download approved Versions of VPN-Clients.
Today I tried to add a new entry but faced the problem, that for now I'm not able to add a Link/URL in entry.
The Field doesn't exist anymore.
Even if I edit an old existing entry, I'm not able to edit the Link/URL
As we update the entries only if needed I can't say when it occoured.
But we made our big DVLS & RDM Upgrade a month before and there it was available (DVLS 3.2.2.0, RDM 11.5.4.0)
Kind Regards
Markus
All Comments (10)
I think I know the problem. We moved the URL field into the Login(Web) panel. I will add a setting to display the url even when it's not a Login(Web). The workaround is to select Login(Web).
Hi David,
that might work for new entries, but if I try to edit an existing entry I can't, even if I select Login(Web/Account)
Kind Regards
Markus
I have another workaround. You could go in the Copy menu and in the Preview you should see the URL. I will try to add the patch quickly.
Better Solution:
export existing one, edit, import
Kind Regards
Markus
I think we should also add in the Software/Serial panel a Download url field.
yes, thats what i use this url-field for.
Kind Regards
Markus
Hi David,
today i checked again and download-field is there, so i can enter again.
But a few suggestions:
Kind Regards
Markus
What do you mean by merge this two fields? Just for the overview?
yes,
plus open button (see the Globe-Symbol).
would that be possible?
Kind Regards
Markus
Thank you. Suggestion added.
