Is there anyway to use advanced parameters with the built in SSH Shell?
I have connections that I need to access via PAM in a particular way. An example of something that works via cmd/powershell (first with $variables$ and then a dummy example):
ssh -t -p$PAMPort$ $MyUserID$@$OurPAMNode$ $remoteuser$@$remotenode$
ssh -t -p57 garry@privaccess.example.org root@exampleappnode04
I have tried every possible combination of VPN/Gateway/Tunnel etc that I can imagine. Is there a way to achieve the same functionality using the built in ssh shell?
In our SSH Shell session, there's a tab to configure a Jump Host. Is this what you are looking for?
It is not. What I need is a SSH session that allocates a TTY for the command '$remoteuser$@$remotenode$'
The SSH Shell session is our own integration of Putty.
How do you make this work in putty? Could you post some print screens.
