AWS EC2 Console - Few Small Bugs
sheldonhull
Disabled
1. If filter applied, and console refreshed, the filter is lost
2. Case sensitivity for the filter box is applied, please consider removing for ease of use in this scenario
3. Dash symbol being processed as negation when part of a string. For example SERVER1-PROC would fail to show for "SERVER1-". Please consider allowing the dash to be considered when trailing or part of a string.
thanks as always for your great support!
I have assigned this to Samuel.
I've made changes AWS Console that will be available in the next patch. The filter should still be applied after pressing refresh and the filter is no longer case sensitive although I could not replicate your dash issue. Make sure its a normal dash and not a dash like character. We do not exclude any character from the search. If its still an issue consider giving us a bit more details.
Samuel Baker
sheldonhull
Disabled
thank you. The dash is just the minus character. It negated the entire partial match as mention for me. I'll see if still does this after your update. thanks again!
