Group/Folder sorting problem with swedish letters
Hi
There seems to be a problem with group/folder sorting and swedish letters Å Ä Ö, they seem to be sorted as A A O
Have this problem with SQL database and DVLS , but I have also tried with your Devolutions Online Drive
RDM client 12.5.10.0
All Comments (6)
How this should be sorted?
It should be sorted like this
https://en.m.wikipedia.org/wiki/Swedish_alphabet
Å Ä Ö is the last letters in the alphabet but is sorted as A A and O
Thank you. I will verify what we can do. Usually we use the default sort implementation.
Ok,
I've found that .NET will sort it correctly if the culture is set to Swedish:
https://msdn.microsoft.com/en-us/library/a7zyyk0c%28v=vs.71%29.aspx?f=255&MSPPError=-2147217396
Could you try to change the application Language in File->Options?
HI David
Yes, changing language to "Swedish" makes the group folder sort correctly according to swedish characters.
Would it be possible to make this sorting work in a future release even if you have "English" as language ?
Unfortunately it's does not seems to be possible. We have to change the Culture in the running thread. I will investigate but I can't promise anything.
