FreeRDP not using RD Gateway
When using FreeRDP als RDP client in Remote Desktop Manager we're unable to connect when a RD Gateway is set.
All Comments (7)
What version of RDM are you using?
What is the error message that you receive when you try to establish the connection?
Hi Jeff,
I'm using version 12.5.4.0.
The message is "Unable to connect to host <internal servername here>"
Hi Roel,
Is there anything particular about your gateway, setting wise?
Would it be possible for us to connect to a test machine using your gateway?
Jonathan Lafontaine
Hi Jonathan,
We don't have any strange configuration. I've tested this with multiple RD gateways.
I don't have a test machine ready to go.
We were able to find a gateway on one of our test servers that we had trouble connecting to.
After further investigation, I was able to pin point the problem and fix this issue.
A beta version will be released later today with this fix included.
Hopefully, your problem is related and this version will solve your gateway issues.
Jonathan Lafontaine
Just tested it, it's not 100% yet.
When using the option "Use same RD Gateway credentials as remote computer" it asks for credentials. When using custom credentials it works fine.
Closed
