Small cursor in RDP sessions on NON-high DPI machine
RDM 12.5.5.0 on a Dell Latitude 7480 running at 1920x1080. This is NOT a high DPI screen and I am at 100% scaling. When I make a connection to any machine via RDP the arrow cursor is really small. The text select 'I bar' is so small it disappears. This happened recently and not sure if I hit a setting somewhere.
RDP sessions outside of RDM do not exhibit this behavior. The cursor sizes are correct.
I do run RDM with the same account across 4 machines....including a Surface Pro that is running high DPI at 150 or 175 scaling. Don't know if that somehow carries over to other machines. The other 2 machines I run RDM on are at 100% scaling.
All Comments (48)
Could you please attach some screen shots depicting the behavior?
Marc Beauséjour
Trying to take a screenshot and the cursor is not showing up in RDM or mstsc.....so here are some pictures from my phone.....
Sort of hard to tell.....but in the RDM picture the cursor is really small (50% size or so) and connect with mstsc to the same host, it is normal size.
