right click on the menu registers as a left click
If I right click on a RDP host and then right click on say "log off" it registers this as a left click and logs the session off. This is a HUGE problem that hosed one of our servers because :
1: logoff is right next to disconnect (these should NOT be right next to each other)
2: accidentally right clicking on logoff during a windows update messed up one of our machines.
Do you think that a confirm message could help?
A confirm message for "logoff" would be AWESOME
(and do not **** off people who don't want a confirmation make it available to be turned on/off in the options menu.
"Display RDP logoff confirmation" (Yes/No)
I still think though that LogOff should not be right next to disconnect session.
The order should really be:
Focus Session
Close Session
Reconnect
LogOff
*However you should still fix the "right click registered as left click" issue while you're at it since this would technically be a GUI bug. A right click on a menu item like "focus session" shouldn't do anything, only a left click.
edited by cyr0nk0r on 4/3/2013
I will add the confirmation. For the right click bug, it directly in Windows. I've just tried with a menu in chrome, a menu in another software and they all behave the same way. I have also verified if I can intercept that but it appears that there is nothing we can do.
