looking for help with a quick powershell script
I need a script that will output a list of the computer names for all of my sessions. If it matters the sessions are RDP sessions.
All Comments (4)
What output would you like? Will CSV be ok?
Thanks
Maurice
yes CSV will be fine. Ideally include the folder name as well but I am sure I can figure that part out if complicates things.
Should be very straightforward:
get-rdmsession | select-object -property Name,HostResolved,Group
David F.
Thank you David :)
Maybe just to add more things to your suggestion to get only the RDP sessions and send them into a CSV file.
get-rdmsession | where {$_.ConnectionType -eq "RDPConfigured"} | select-object -property Name,HostResolved,Group | Export-Csv c:\temp\test1.csv
Érica Poirier
