hi, i tried everything:
reset layout
delete lyt files
nothing worked. any suggestion, please?
MB
Could you send us a screenshot?
You can use support@devolutions.net or a private message if you prefer
Maurice
mmm mistery: after reboot pane appeared. sorry for time waste
omg
disappeared again:
sorry but it's quite crazy
This is really strange.
Could you please try and go in %LOCALAPPDATA%\Devolutions\RemoteDesktopManagerFree and delete the file RemoteDesktopManagerFree.ext?
Marc Beauséjour
No effect.
Could you try the following:
Close RDM
Navigate to %localappdata%\Devolutions
Copy the RemoteDesktopManagerFree folder on your desktop
Delete the RemoteDesktopManagerFree folder in %localappdata%\Devolutions
Restart RDM
This should create a new RemoteDesktopManagerFree folder in %localappdata%\Devolutions. If everything is back to normal, close RDM again and copy the 2 files below from the folder RemoteDesktopManagerFree on your desktop in %localappdata%\Devolutions\RemoteDesktopManagerFree to recup your configuration and your local data source.
RemoteDesktopManagerFree.cfg
Connections.db
Hi, it worked and it's stable.
Just a point. I didn't copy the folder to desktop. I just renamed id as xxx_old.
Reagrds
M
