Using same credentials for RD Gateway puts password as username in windows Database
patrick06
Disabled
i have about 600 Entries in my database, so i rely on saving the passwords in my database, not in Windows.
However, when i select "Use same RD Gateway credentials as remote computer" RDM creates an additional entry im my Windows Password database as soon as i open the connection.
This wouldnt be a problem, if it wouldn't create the entry in some weird way: It puts the password as the username, so in my windows database my gateway passwords are all stored in plain text.
i added screenshots to clarify.
All Comments (4)
Are you using the 32 or 64 bit edition?
Hello Patrick,
We have been able to reproduce your issue.
I attributed this topic to our engineering department.
David Grandolfo
Patrick,
The issue has been fixed internally and the change will be available in the next version of RDM.
Thank you very much.
This was a lot faster than i expected. Took me some weeks to figure out that this was a RDM problem.
Just installed the update, now the creds are written correctly.
