iTerm Connection Setup - Not changing FONT settings
andre01
Disabled
I'm trying to change the FONT settings for the iTerm connection and it does not change from Monaco (12pt). I noticed that when I changed to "Source Code pro for Powerline" 11pt, it appears to save, but it doesn't show at the settings dialog (always Monaco (12pt)).
The iTerm session is always using the same font (Monaco) and not changing font or size.
Thx
All Comments (6)
I just tested and I'm not even able to change it so the Monaco (12pt) label changes. Is that your issue?
This must have somehow broken between releases.
Xavier Fortin
andre01
Disabled
you are right. The text does not change and it also not changed in iTerm.
But somehow you must save, because when I open the dialog to select the font, it does show the last selected font and size.
And just to avoid misunderstanding, the issue is not only with the label, but also the selected font/size is not used in iTerm the way it is supposed to.
I think it's the font panel (which is a Mac control) that remember the last selected font, not the session.
Xavier Fortin
andre01
Disabled
Do you know when the next update will be released with this fix? Thx
BR,
Andre
I didn't have the time to investigate this yet, so I can tell you it won't be in the next release. This is not definitive, but I'll try to find a fix for this in the release after it.
I'll post here when a version with a fix is out.
Xavier Fortin
This has been fixed and it made it before the release of the next version. So you should find it in the version that will come out in the coming weeks.
Xavier Fortin
