RDM with iTerm and connection type SSH
andre01
Disabled
I'm trying to create a connection using iTerm and connection type SSH. I'm filling the user and password but when trying to connect it just appear:
Password:
Password:
If I type the password, it will login to the server (Linux).
When I create a normal SSH connection using user/password it works normally and it will not ask me to fill user or password.
An alternative would be to connect using iTerm and using the connection type: command
The issue is that I tried many things and options I found in google, but it didn't work.
My password contain characters similar to: #dEf$@!$2
Thx
PS: Using 4.2.1.0 (macOS)
All Comments (7)
Hi Andre,
Just to make sure, the connection that fails to fill your password is the iTerm connection, right? Not the SSH Shell connection?
Xavier Fortin
andre01
Disabled
Correct.
It doesn't show the USER text, but it shows the password text and later again and it waits to fill the password.
This is what appears:
Password:
Password:
Initially it appears the first password and second later the second password text.
andre01
Disabled
I tested with another server which uses a simpler password with:
- letters
- numbers
and it connected properly. I believe the problem is when passing some different characters?
As mentioned before, the server which I attempt to access yesterday had a password with the characters #dEf$@!$2
Thx
Hi Andre,
Thank you for investigating this further. We'll look this up.
Xavier Fortin
andre01
Disabled
Something else which I also noticed. The server I connected Today and worked is a RED HAT LINUX and it showed:
user@address's password:
The server yesterday was a SUSE LINUX and showed only
Password:
Maybe you are expecting always the "user@address's password:"?
I must admit that I'm not sure of this myself. I don't think it should be an issue. But one never knows.
Best regard,
Xavier Fortin
Hi Andre,
The exclamation mark in shell command is a special character and (contrary to most) cannot simply be escaped in a string surrounded with double quotes (""). In the case of the previously mentioned string of character, !$ even surrounded by double quotes is a variable corresponding to the last command sent. This, of course, corrupted the password, explaining the failure to connect.
This has been fixed internally and should be in the next release of RDM.
Xavier Fortin
