Passwords syncing between servers with the same IP
We support multiple customers and some of them have servers on the same IP address. When I change the password on one server it automatically changes the password entry on the other server.
Is there a way to disable this function?
Thanks,
Ben
All Comments (11)
  • What types of entries are you using (RDP, SSH, etc)?
  • Are you using our shortcut feature (tiny arrow overlay on the entry icon)?
  • How are you storing the password (directly in the entry, in a credential entry, etc)
Maurice
I am using RDP connections and storing the password in the general section under store password on the local computer.
I don't think I am using the shortcut option.
I can reproduce the problem by simply selecting
- new entry
- Microsoft Remote Desktop (RDP)
- enter whatever in the name and domain field.
- make sure the username and the server ip address are identical with a second entry.
- passwords will sync. When one is changed the other will change to match.
Thanks,
Ben
Hello Ben,
Do you open it in external mode?
If you are talking about RDP then I doubt it makes a difference. I can see the password changing when I select view password without even opening a connection.
But no, I use RDP in Embedded mode.
This is very strange indeed. What data source type do you use?
So using the "store password on the local computer" means that you are in fact using the Windows Credential Manager to persist the password.
As per our topic on RDP sessions (https://help.remotedesktopmanager.com/session_rdp.htm)
Use the Windows Credential Manager to store passwords. It is not the best option because it has the following limitations:
•The Credential Manager will hold only one entry per host, therefore if you have multiple sessions towards the same host, the last saved entry will overwrite whatever was stored.
•The one host limitation ignores the port, therefore multiple sessions towards the same host, but with different ports, will conflict as well. Last saved entry overrides whatever was stored.
The alternative is to store the password in the database, they are encrypted using AES 256 bit encryption so they can be read only using RDM. For additional security with something that only your organization knows, use our Security Providers to encrypt the whole connection data with an additional passphrase. (https://help.remotedesktopmanager.com/administration_securityproviders.htm) Note that this is only available on Advanced Data Sources (https://help.remotedesktopmanager.com/DataSources_Advanced.htm)
Maurice
Oh right, that makes total sense. I will use the database option from now on.
Thanks for the help.
Ben
jjjbos
Disabled
For the developers of RDM:
There is possibility to store different credentials for the same machine in the Windows Credential Manager:
- Store the credentials with an own unique identifier per connection.
- On starting the RDP session, copy first the credentials to "TERM/DNS name or IP address" and then start the RDP session.
This mechanism does work, because I have used it in my own autoit script for manging RDP sessions.
Jeroen Bos
Thats what we do when you specify to store the passwords in the db ;)
Maurice
jjjbos
Disabled
I understand, but with storing the credentials in the Windows Credential Manager all the cryto is done by Microsoft (of course you'll have to trust them) and you don't have to worry about that.
Yes indeed.
But one of the primary reason that our communityuses RDM is the possibility to share passwords in a secure fashion. This implies that it comes from a central location.
My favorite aspect is that I never handle a password, the system administrator takes care of that and the rest of the team simply focuses on managing systems rather then passwords.
Again, RDM is flexible to the extreme, it can adapt to YOUR concerns and allow for MANY scenarios.
Maurice
