Dashboard view issue when $parent_host$ variable is used for name
found a bug if the variable is used in the connection name. in the navigation panel the view is ok, but in the dashboard view the connection name is doubled attached.
attached some screenshot for a better understanding :)
Tested with actual live version (12.0.8) and with latest beta (12.16.0)
Min
All Comments (2)
Hello Min,
This isn't a bug, but I understand why this is confusing in your case. The text we show is the following
<parent connection name> - <subconnection name>
In your case $PARENT_HOST$ happens to be the same as the name of the parent which makes it look like it's just showing twice.
We will add an option to disable this behavior and instead show only the subconnection's name. It will be located in File > Options > User Interface > Dashboard
Hello Hubert,
ahhhh my fault -sorry! Make sense what you say - sorry for the misinterpretation!
An option for this would be great!
As always - many, many thanks for your great support! :)
Min
