[SOLVED] SSH Shell: do not disconnect while idle
Using SSH Shell connection, my tabs are disconnected after some time when I'm not active. I'm trying to keep them open even when I'm idle. I believe that the "KeepAlive interval" setting (shown below) is what I'm looking for, but this is for SSH Shell Rebex. Is there an equivalent for the basic SSH Shell connection?
All Comments (24)
In the advanced tab of the SSH Shell entry, you should have the following option:
Just check the "enable tcp keepalives" and set a delay, and it should work.
