Port check should recognize custom port on http entries
Right now when you click "check is online" on an http entry with a custom port in the url it still checks port 80.
Https is also not recognized for port 443
Thank you for notifying us. We have identified the issue and it has been fixed internally. In the next build of RDM it should correctly use the custom port set in the URL.
Thanks!
HTTPS detection as well?
Yes, it will automatically set it to 443 instead of 80 if the URL is using HTTPS.
